I kinda leaning this way too, or when was the last time you cleaned out the 2000 pounds of "stuff" that a boat collects. You had better get rid of the "Rattle", or your gonna toast the motor...detonation is a motor killer. If nothing else, back the timing down until its goneOriginally posted by LubeDude:<br /> Maybe you are over propped just a little,
The 140 ci is a ford block isn't it?<br /><br />My t-bird has the turbo 2.3 and with anything less than 90 octane it knocks horribly, and occasionally even with 90. With 91+ it's as smooth as can be. Even with 250k+ miles, 15 psi, and a couple degrees advanced timing.Originally posted by jlshields:<br /> My daughter had an '84 Olds Cutlass with that same engine and it sounded like a diesel.
The 140 is a 3.0 liter, 181 cu inch GM block . . .Originally posted by Liquid_force:<br /> The 140 ci is a ford block isn't it?
Ayuh,..........<br />It'll Destroy your Bank Account........but is there any concern that this higher octane could do any damage to my engine over time?
Ah, my bad, I saw 140 and for some reason immediately thought ci.Originally posted by Quietcat:<br />The 140 is a 3.0 liter, 181 cu inch GM block . . .Originally posted by Liquid_force:<br /> The 140 ci is a ford block isn't it?
