Here I am again. Trying to get this 55 HP Chrysler running. I have turned the motor over without the plugs in after spraying the cylinders full of WD-40 and it really turns over good. It sprays a good plume of WD-40 out of each cyliner. However, when I put the plugs back in, the starter will barely turn the motor over. I mean VERY slowly. I'm confident the starter is okay. The battery is good. The only thing I can think of is I'm using jumper cables to get power to the motor. Is there such a thing as a stuck exhaust valve on this motor???
