tohatzu 40c missing at half to full trottle run great at idle to half HELP!
rusty o
changed plugs X3/cleaned carb,/new tanks/new lines/new bulb/installed wt. seperator/checked timing/checked firing/please help
pvanv
Re: tohatzu 40c missing at half to full trottle run great at idle to half HELP!
How's the fuel delivery from the pump? What is the float setting? What is the timing at initial and WOT?
rusty o
fuel pump is pumping plenty of fuel/don't know about float setting was very carefull when i cleaned it/checked timing last week slightly high,going to try another set of plugs champion this time/one more thing was using pennsoil small engine oil mix and switch to synthetic pennsoil and notice a white milky substance in carb, when running any ideas
pvanv
"White milky" usually means infused water. That may be your issue. The best plug to run is the NGK BP7HS-10, either resistor type or not, depending on your preference and the local availability. You may want to check compression and have a look at the reeds -- while very durable, you could have a reed stop out of whack, or a slight crack in a reed.
