lots of boats
- Jul 28, 2008
- 116
I have owned about 75 outboard motors, over many years and many thousands of hours. Nine of the most recent have been tohatsu 90 TLDI, of those nine four of the most recent have failed due to detonation. Tohatsu blames us. They offered no warranty repairs and had no blocks available for repairs either. They say the cause is poor fuel, bad oil, wrong pitch user error etc. No warranty allowed. The four that failed were all close in serial number. Two were used in one type of application by one person, two others that failed were used by other operators, different loads, different boats. There is no detonation sensor on these motors. It wasn't the same cylinder every time. Two of the motors had the rod come through the side of the block when the piston stuck and the rod broke. One of the motors had the rod almost cut the block in half, smash the air pump and the vapor seperator, cut an oil line catch fire and blow up. The first five 90TLDI are all running, all in the same applications as the last four that all failed. My latest guess is that the injectors are leaning out. I have heard of other similar recent failures. Has anyone else had this problem and found the cause?
