I have a Tohatsu 5 hp MFS5B. I bent a blade on the original prop and replaced it. Along with the new prop I got a prop hardware kit with a new nut, thrust washer, flat washer, and cotter pin.
The old thrust washer is stuck tight to the splines on the shaft. The boat spent a lot of time in salt water before I got it, and there appears to be corrosion that has seized the thrust washer to the shaft. The shaft is not bent or damaged in any way. How can I remove the thrust washer without breaking something?
Also, is there somebody you would recommend for repairing the old prop?
Thanx.
Thanx.
