Talk about projects getting out of control!!<br />Does anyone know the bore size and piston diameter for a 1993 tohatsu 90hp? Also what are the tolerances(if any) on these sizes?<br />Thanks, Matt
mattsaks<br /> look in the service manual under engine specifications. wiesco makes after market pistons pins bearings and circlips. youcan check their web site as well. Ithink the standard bore size is listed there.<br /> good luck and keep posting
Matt,<br /><br />Piston max diameter (measured 10mm above the lower edge of the skirt) is..... 85.93 +- 0.01mm.<br />Piston clearance is 0.08 - 0.13 mm
Clymers' conversion is off, Marubeni manual shows max bore of 86.50 mm(3.43") ring gap .8 mm(.031"). Manuals do lie,I'm too lazy to break down a powerhead to check.Edit; can't blame Clymers for all of it, I read the bore #'s wrong, they have86mm(3.386") The inch conversion I believe is shifted over one column which would give a piston clearance of .0031-.0051 and a ring gap of .010-.016.Thanks to the web for peer review
