Re: Tohatsu oil consumption
Hi Tohatsu Guru,
Hoping you can shine some light on a problem I have. My 2001 115 HP (model M115A2 3J6) two stroke Tohatsu seems to be consuming too much oil and running rough as a result. Oil deposits are visible on new plugs even after a few minutes of running.
Compression is 135psi across all four cylinders. I hooked up an external tank to the engine with pre-mix gas, disconnected the oil line from the fuel pump and measured the output of oil at 1500 RPM. The result was 6ml in 4 minutes. This would be equivalent to 22.5 ml in 15 minutes. Is this normal? Do you have any numbers for this engine?
Engine seems to be running rough in general. Carbs are clean, no stuck floats or needles. The idle mixture screw is set at about 1 and 1/2 turns on each carb. Oil deposits are even on all plugs. Exhaust smells fuel rich, but if I cut back on idle mix adjustments engine runs rougher.
The only adjustment to the oil pump operation appears to be via the linkage to the throttle arm. If I were to tighten this linkage I think it would have the effect of reducing the oil consumption as designers intended at higher RPMS.
Comments from others appreciated.
Thanks.
