Tohatsu / Nissan 6hp 4 stroke engines
audeojude
I had the opportunity to work with a friend on his boat yesterday and I took the inline scale and a tachometer with me to test the performance of the engine in a static thrust test. We also did this with both the stock 8 pitch prop and a 6 pitch prop.
The tachometer is a Sendec unit good to 7000 rpm in 10 rpm increments.
The scale is a 3000 lb loadcell scale accurate to the nearest 1 lb increment.
I have been wanting to do this for a while as I have the same engine only marketed under the tohatsu brand and it has run weak since I got it. I had assumed that there were problems with my engine but based on the test results I think that there is a much larger issue.
The Nissan engine produced identical test results in RPM and thrust for the static tests with both the 6 pitch and 8 pitch props as my Tohatsu. Both engines with the 8 pitch prop could only turn 3700 to 3800 rpm and produce an average 124 lbs of thrust. With the 6 pitch prop they both turn about 4300 rpm and produce an average of 165 lbs of thrust. With the 6 pitch prop this does produce more thrust at low rpm and in static tests. However on the water this does not equate to better high end performance. The drop in pitch actually needs the engine to turn more rpms to maintain the same speed at the top end. Unfortuanatly even with a 6 pitch prop the engine does not produce enough power to even match the manufactures specified nominal 5500 rpm.
For this engine to output 6 hp the engine has to be at 5500 to 6000 rpm. On the water not tied to a dock the engine will produce a little more rpm.. It will with the 6 pitch prop get to around 4700 rpm. This is still 800 rpm below the 5500 rpm nominal and 1300 rpm below rated max rpm. The difference in 800 rpm on the thrust produced is large, 1300 is simply huge.
My conclusions based on these tests is that Tohatsu/Mercury/Nissan all the names this engine is branded under are over reporting the power produced. Their 6 hp engine produces approx the same output as a 4hp 2 stroke engine.
When I replaced my old 4hp engine with this one I was looking for more power, better fuel economy and queiter operation.
1. Power
The power is the equivalant of a 4hp 2 stroke engine based on static thrust tests (based on testing two engines-one Nissan and one Tohatsu) at the dock. On the water on the same boat that the 4hp engine was pushing the week before , the boat actually lost about 10% of its through the water performance. Going from a top average over the water speed of 5.76 knots to 5.35 knots. I had actually lightend the boat during this time period also in cleaning out a bunch of stuff that had accumulated on the boat. My expectations were sadly let down with this engine. It not only doesn’t give me the extra safety margin I had looked for in a engine 50% more powerfull than my old one it actually is just slightly less powerfull.
2. Fuel Economy
I have to give the new engine top rating for comparative fuel economy. A three gallon tank will give almost 30 nautical miles range with the new engine. This is more than twice the range I had with the old engine. It meets the stated .5 gallon per hour fuel consumtion give by the manufacture.
3. Noise and Vibration
I was expecting a much quieter operation with the new engine and it failed to give that. It is almost as loud as the 2 stroke at WOT (wide open throttle) which is the normal operating speed needed to fight the currents here. Also the engine vibrates even more than the two stroke. The Manufacture told me that this is normal as it is a one cylinder engine. The vibration is bad enough that it vibrates the whole boat at speed and if holding it the engine tiller handle will numb your hand after a while becuase of the vibration.
Another effect of the vibration and a badly designed friction adjustment on the unit is that it will not hold itself straight unless you hold onto the tiller handle. ( the friend with the Nissan version reports the exact same issues) At low rpms the torque of the engine running will instantly turn the engine to the side if not held and at WOT it will gradually twist sideways. For those in dingys and such that use the engine to turn/steer with this shouldn’t be that much of an issue as you are constantly holding the engine tiller handle anyways, but on sailboats (which it is marketed to in the long and ultralong shaft designs) it is a major problem. We have a boat tiller or wheel that we steer with, not the outboard. If not closely monitored it will introduce course changes when your not expecting it while under power.
I would imagine that this data holds true over the entire line of the 6hp engines having these model numbers. Mercury also puts these engines out but I don’t have the model numbers offhand. As to the 4 and 5 hp engines that are based on the same engine and chasis, I have no test data to say how they perform. I can only think that they will be quite weak, as well as having the same issues with vibration and noise.
MFS6BS, MFS6BL, MFS6BUL for the tohatsu’s
NSF6B1, NSF6B2, NSF6B4 for nissan
I would be interested in others experiences with these engines.
coastalcruiser
Re: Tohatsu / Nissan 6hp 4 stroke engines
I have a 2000 mercury 6 hp 4 stroke.
I think it has lot's of power just vibrates and sounds like its going to blow up at full speed:eek:
TOHATSU GURU
All outboards are measured in the same way. At a specified RPM the engine generates X hp at the prop. There is no over or under reporting of anything by any of the manufacturers in this regard.
