Re: Tohatsu Model M20A Electrics
The size of the battery used is a non-issue in a charging system. The only factor associated with it is how long it takes to charge. A very large capacity battery will take longer to charge than a smaller one. If the outlet you are talking about is a charging connection, you should see about 13 to a maximum of 15 volts at wide open throttle. I would guess the charging system output is about 5 amps or so. If your boat electrics draw 5 amps total and you fished for an hour, you would need to run wide open for an hour to charge the battery. Think of the battery as a small bucket of water. If the bucket was full and over an hour you used a quart of water for whatever reason, you need to replace a quart when you get back to the dock. Likewise if the bucket was a very large one, you still only need to replace a quart. Large battery capacity allows you run longer between charges but it takes longer to charge them.
