It seems everything is taking longer than I think. And it hurts more also. That aside , I may be mistaken but I thought I saw someone mention putting a gasket on the top housing of the pump body as a remedy to its' leaking. As a certified T technician I realize this method would not be used, nor recommended by T but might it work? Or is the diaphram within damaged, causing the leak, which will only get worse with time ? Thank you for your reply.
