Tohatsu M90 Tilt trim fluid?
bowtoot
Where do you add the t/t fluid? I looked through the manual but I am unsure. A perfect noob question though.
bowtoot
Re: Tohatsu M90 Tilt trim fluid?
I got the ATF part but where do you add it on a 1992 model? Looking at the manual I don't see a resevoir that looks like the one in the book.
bowtoot
I think I got it. The bolt is screwed in horizontally to the resevoir which is on the right hand side of the motor when looking at it from the back. I added fluid then operated it. It went up slowly then I tried to bring it down. It was like it was stuck, but the pump was running. I opened the filler bolt again and got bubbly fluid coming out. I closed it and tried again. I had to let it down by opening the auto/manual valve. I repeated the air bleeding steps and seethat I need to do this over several days in some cases.
