Hello,
experiencing top end RPM low and poor acceleration on my tohatsu m70b. Furthermore, starting difficulty with misfirngs occurring already at low rpm till the motor shuts off.
Cheked out ignition coil primary resistance with good ohmeter: 0.21ohm
Cheked out ignition coil secondary resistance with good ohmeter: 4500ohm
Cheked out alternator coilresistance with good ohmeter: 0.24ohm
Cheked out Exciter coil output at cranking speed with DVA: all three values widely above the specification listed in service manual (one 40V instead of 9V, other two 155V instead of 35V)
According to the service manual, i hence checked the pulser coils with DVA at cranking speed: one pulser coil outputs 4.55V, the other two coils output 3.4V.
Is the procedure above correct? If it is, does it mean i should replace the pulser coil?
Are pulser coils sold separately or should i buy the pulser coil assembly?
Thanks for your attention
Luca
Luca
