Re: Tohatsu M60B Tilt Trim Switch
The boat that I bought was used (and abused). I have fixed a short in the switch and replaced the wires in the control box on several occassions and am tired of always having to open the control box in order to repair the wires. By mounting the tilt/trim on the console next to the throttle, it should not distract me should I need to trim the engine at higher speeds. As well, when operating bigger boats, the tilt/trim is often located separate from the throttle. As long as you are familiar with the layout of the switches prior to taking the boat out, it should not present a problem. <br /><br />I was mainly concerned about wiring issues. It seems, that as long as I have a direct connection to the battery and then run to the solenoid from there, it should not be problem. Has anyone else tried this?
