Hi
I have some water in cylinder .....
Now i try to change oil seals and o-rings on Cranck Case Head and Upper Main Bearing.
From parts catalog i take serial numbers and measures but i can't find those types of seals and o-rings nowhere.
Some strange measures .......
Oil Seal Upper on Crankshaft --- 36,5 x 46 x 8 mm--- sn. 353-00121-0
O-Ring Main Bearing Upper --- ? 2 x 44,7 mm --- sn. 353-00108-0
Oil Seal Drive Shaft --- 16,8 x 28 x 6 mm--- sn. 353-01215-0
Oil Seal Lower on Crankshaft--- 30 x 45 x 8 mm --- sn. 126-00121-0
O-ring Crank Case Head --- ? 2 x 66,5 mm--- sn. 151-00053-0
Any idea where to find them ?
Or maybe some similar measures ?
Thanks in advance
Thanks in advance
