Hi
M40D Outboard has given perfect service for 4 years, then today......
Salt water used, not flushed with freshwater for a while (as Summer season boat yard has no facilities)
A few weeks ago, on two occasions, while running, engine would only go to half speed, as if running on two cyls, then kicked in, and ok. I dismissed it.
Started fine today, motoring along fine, with pee hole ok. suddenly, extreme overheat, with smoke coming out from under the cowling. No overheat sensor fitted
Engine died. Engine very very hot! (a plastic screw plug in the cylinder block melted) 30 minutes to cool down, started fine and ran well, did not get hot again, pee hole fine.
But after stopping and fishing for 2 hours, engine very difficult to start, then running like it did a few weeks ago, on half speed, sort of droning along.
While under way, pulling lead off plug 3 made no difference to revs
So cylinder three not working...
Would it be related to the overheat, or a coincidence?
Why would cylinder three die? a new coil perhaps?
Haven't tested for spark on cylinder 3 yet (I neeed to get the boat home first), plug was oily
Any advice would be welcomed, as I am in England where Tohatsu service centres are few and far between
