Have a 25hp Tohatsu that MAY need throttle linkage and carb sync. THe engine starts first pull, idles great. The problem is that there seems to be no "mid-range" throttle. It's either off plane or wide open throttle (WOT). When WOT there is a surge in the rpm, not that great but noticeable. If I try to back off a little bit it the RPMs drop off quickly and falls off plane.
Any suggestions?
Thank you, Karl
Any suggestions?
Thank you, Karl
