I'm trying to pull the lower unit off my Tohatsu M50 D to replace the water pump. There are (2) pins, upper and lower on the shift rod joint. Is the upper pin the one to remove?
I broke a punch trying to knock that one out. The lower one is a spring pin which pushes out easily. Any suggestions on how to remove the stuborn upper one? What size should I replace it with assuming it is not reusable?
Thanks for your suggestions.
Mike
Mike
