Tohatsu carb jets
mattsaks
Tohatsu m90a 1993<br />Which one is the low speed jet? (is there one?)<br />There are two in the main bowl, one is under a rubber cap. It is the smaller one. Is this it?<br />Also, the idle mixture screw. Which way is rich and which is lean?<br />Thanks
TOHATSU GURU
Re: Tohatsu carb jets
The one under the rubber cap is the slow jet. The idle mixture screw is set at 1 1/2 +- 1/4 turn. On our engines....to the left(out) makes it richer.
