What is your actual model? On the MFS9.8A3, there is the idle stop screw, which adjusts idle throttle. On that carb, if manual choke, there is also a screw to advance the idle throttle when choking. On all 9.8 carbs, it is also possible to adjust the low-speed air/fuel mixture, but, as Luis noted, don't tinker with that unless you are an expert.
