Tohatsu 9.8 carb question
raczekp1
Maybe someone can help me. I nned to know one thing. Just over chocke plate inside the carb is a venturi hole. what the noumbers are stamped inside? or can any one measure venturi diameter taken ftom chocke plate side?
pvanv
There are only 2 different carbs on the MFS9.8A3. The difference is the choke operation; the electric choke model turns the opposite of the manual choke version. The M9.8B (2-stroke) is completely different. What is your actual model, and what is it you want to know?
raczekp1
well i have carb taken from internet auction. i know its from tohatsu but not sure if its from 8 hp 4stroke or 9.8 4 stroke.
i need to identify this carb becouse i.m gong to fit it to yamaha 9.9 4stroke.
in venturi troath is stamped " 12"
so its from 9.8 or 8 hp ?
Sea Rider
8/9.8 HP-OB's have less CC than a 9.9 OB, whether being 2 or 4 strokes OB's. Get a 4 strokes 9.9 Yam carb.
Happy Boating
pvanv
Tohatsu carbs are identified not by venturi but by casting number. The 9.8 manual choke version is part number 3V2031003M, while the electric choke version is 3V2031333M. The 8 hp version has a MUCH smaller throat. The 8 hp manual choke version is part number 3V1031003M, while the electric choke version is 3V1031333M. You can call Tohatsu America at 469-771-3740 to check the casting number.
