Tohatsu 9.8 4 Stroke Running Rough
NJS0930
I have a 2005 Tohatsu 9.8 4 stroke that just began running rough under load. The motor has approximately 20 hours on it. Starts and idles fine, but under load and up to full throttle it misses and runs rough. I have replaced the small fuel filter under the motor cover, and removed the carburetor and cleaned the jets as best I could with carburetor cleaner. Any other suggestions? The fuel supply is connected to my water/fuel separator filter that I use for my main powerplant. Thank you.
TOHATSU GURU
Re: Tohatsu 9.8 4 Stroke Running Rough
Since your engine engine is still in warranty you should take it into a local service center for them to determine the problem.
NJS0930
Thanks for the advice. None of the authorized Tohatsu service facilities are convenient to me. The closest one never answers the phone.
I pulled the carburetor apart and cleaned it up. Reassembled with a new fuel filter and it runs perfectly. Cleaned up the rest of the fuel system and all is well.
TOHATSU GURU
Just for future reference. The five closest are:
Company Allison Marine
Address 23431 30th Ave. South
Kent WA 98032
Phone 206-878-6479
Distance Approx. 6 Miles
Company Hilton Outboard
Address 3914 Center Street
Tacoma WA 98409
Phone 253-627-1915
Fax 253-627-1109
Distance Approx. 12 Miles
Company Sorensen Marine Inc.
Address 9808 17th Ave. S.W.
Seattle WA 98106
Phone 206-767-4622
Fax 206-767-5832
Distance Approx. 16 Miles
Company Mercer Marine Inc.
Address 3911 Lake Washington Blvd. SE
Bellevue WA 98006
Phone 425-641-2090
Fax 425-641-8579
Distance Approx. 18 Miles
Company Eastside Equipment & Marine
Address 6405-229th Ave. SE
Issaquah WA 98029
Phone 425-392-0146
Fax 425-392-0148
Distance Approx. 21 Miles
NJS0930
Thanks for the list, Elvin. Strange that my search only picked up Allison Marine (the one that never answers the phone, at least when I've called them) and Eastside Equipment and Marine (a bit out of my way).
TOHATSU GURU
If you used the search feature by zip code in the dealer finder the default is for a search of "Sales and Service" outlets. Due to a rather odd bit of marketing, that would only bring up the Tohatsu labeled dealers. The alternate search parameter, "Service", brings up both Tohatsu and Nissan outlets.
TOHATSU GURU
"If you used the search feature by zip code in the dealer finder the default is for a search of "Sales and Service" outlets. Due to a rather odd bit of marketing, that would only bring up the Tohatsu labeled dealers. The alternate search parameter, "Service", brings up both Tohatsu and Nissan outlets"
Who say's that things don't change:) Public forums do have an impact. Big Brother sees all and made a change based on perceived need.
NJS0930
Great news! Thanks for following up on this.
