rhunter73
- Apr 29, 2013
- 13
I have a new out of the box Tohatsu 9.8. I added the engine oil until it was *just* about full, but not quite.
I put it in a test tank *cough* recycle bin *cough* for an break in, smooth start, no worries.
I am taking the outboard out tomorrow for the fist trip.
I wanted to check the lower unit oil, which I understand is prefilled, but I just don't quite understand the instructions.
"To check your oil level, remove the top oil plug, insert a small piece of wire straight into the top hole approximately 1 inch and withdraw the wire. If oil is on the wire the oil level is correct, if not the unit must be refilled to the correct level."
I can't imagine this test to ever show any oil unless the lower unit was overfilled and spilled oil out when you took off the top oil fill plug/bung?
What am I misunderstanding?
Thanks,
Roger
Thanks,
Roger
