Tohatsu 9.8 2006 rock problem
seattl
backed into a hidden rock with my 2006 Tohatsu 9.8 4-stroke. Prop was damaged but engine re-started ok and it carried me home, however, at the top end it suddenly stops pushing. Seems like it hesitates and there is no more power. If I cut the rpm's back then it will start to push again. Any ideas?
Thanks - very new to outboard motors so all advice is welcomed!!
TGuy
Re: Tohatsu 9.8 2006 rock problem
sounds like you spun the hub in the prop. The prop has a hub in the center that's designed to give away if you hit a rock (to reduce the impact and minimize damage to the gears, shaft, etc). Once the hub has been "spun" off the prop, it will hold at lower speeds but at higher speeds the prop spins faster than the hub and doesn't "grap" so you lose power. Most prop shops can fix it although I don't know how cost effective it is on a small prop like that. Might be cheaper to just buy a new prop??
TOHATSU GURU
It's the prop and I don't think anyone offers a hub for that one, so a new one is in your future.
seattl
strange thing is that when I removed the prop the nut was only finger tight - didn't need a wrench to loosen it, so I guess it was being held on by the split pin...
TOHATSU GURU
The nut is usually not that tight as the pin keeps it in place. But, hand tight is a little more loose than normal. Probably a result of the impact slamming the prop back against the washer/nut.
halfmoa
Ensign
^^^It wasn't a Tohatsu motor but that nut tightness scenario happened to a friend and I in just that situation.
pvanv
The MFS8/9.8A3 (year is unimportant, model is everything), has a splined prop hub, so as long as the nut is at least finger-tight, the cotter retains the nut, and the nut threads retain the brass splines onto the shaft. Not a big deal, though I like them tighter. A loose nut will not allow the prop to slip. 99.9% chance the hub is spun. You can get a new prop from any dealer. If your performance was good, reaching near max WOT RPM, stick with the same pitch... if not, this is the time to get a different pitch, that puts you closer to optimum WOT RPM.
