Some issues with inflatables :
To start with : which is your dingly size, is it a air deck, alum, wooden deck or RIB ?
- If not a RIB, tubes must be fully pumped to min 3.0 PSI on all air chambers including keel.
- One story is fast displacement speeds other plane speeds, worst if loaded.
- Size matters, less size more hull drag, larger much less specially with under powered engine.
- You need to tach that engine with you alone on flat calm no wind waters while being lightly loaded, check achieved wot rpm.
- Can go from there maximizing prop to be at min middle 5000 to max 5500 wot rpm.
- Going one less pitch achieves 400-600 + RPM on very light boats.
- Buy a new 9.8 carb and bump that 8 into a 9.8 HP.
- Middle rpm is 5500, max wot 6000 RPM which is a better improvement over an 8.
- Before investing blindly on a new prop, better order firstly and induction Tiny Tach or Hardline tach with programmable firing sequence.
- Bear in mind that if you dial a prop that runs middle to max wot numbers with 3 up, when alone will over rev that engine at wot.
- It's a good idea to have an induction tach installed next to throttle grip.
- Will need to move to a prop pitch around 7.5 to 7.0 with 8 HP and 7.5 with 9.8 HP.
- Dialing best prop pitch is not exact rocket science, must test props under trail & error with given load.
- Plain Theory doesn't apply here...
Happy Boating
