Tohatsu 6hp - minimum gas problems
Matjaz
First, I apologize for my English - it is not my mother's tongue.. <br />My Tohatsu 6hp four stroke sucked water and dirt from the tank (ran out of fuel.. my fault..); since then it dies often on very low revolutions (on minimum gas - while in gear - happens mainly in the harbour!). I had it serviced (carburator cleaned with compressed air and chemically, spark plugs replaced, minimum gas adjusted, etc.) with little success. <br />Minimum gas is even too high now, so that does not help. It never dies in idle. Looks like an ignition spark would be missing and the motor stucks.<br />It looks as if it would need the setting for minimum air flow (which it does not have) together with the minimum gas. What else can I do?<br />This is my last try - I am even thinking of selling it.. <br />Hope you got the problem. Thanks.
Matjaz
Re: Tohatsu 6hp - minimum gas problems
OK, will be done (in a few weeks, I am away from my boat). But, I have less hope - it has been done several times already..<br />Thanks anyway.<br />Any further ideas?
TOHATSU GURU
It is possible that a piece of trash has blocked a passage in the carb. All you can do is keep cleaning it until it works.
Matjaz
OK, thanks again. At least I know nothing else can be suspected (ignition, some "secret" adjustment of the idle air flow,..) Will try again, until I loose my patience.. :rolleyes: <br />Regards, Matjaz
