Can use some help. I do not use the bypass hose to rinse the engine much. I prefer to immerse in water and run. But... I used the bypass tube, threaded on very smoothly, hand tight only, but on removal the brass male threads broke off in the threaded hole provided.
I have little experience using easy outs. Is this the best way to remove the remaining threads I'm worried about damaging the female threads in the motor? Any other suggestions are appreciated.
Jerry
Jerry
