So i have a 6hp 4 stroke tohatsu, about 6-7 years old. It has not been used this winter, now we have put it on the boat again and turned it on. It seemed to run well but as soon as you let the gas below about 30% engine engine starts do loose rpm and die. We took a ride and drove it at full speed for 10 minutes, it was running perfectly smooth at high rpm, you let the gas at about 30% witch is still not that low and the engines starts to loose power/dies.
What should i check?
Also can someone link me a good tutorial that will show me how to change the impeller on that outboard?
