Tohatsu 5 horse 2 stroke manual?
chopper72
Need the manual. It is an early 90's Nissan. Anybody have a PDF? Had a dirty carb. Cleaned it but now it won't turn over even with starting fluid. I did something wrong and will need to follow manual. Thanks!!
Sea Rider
Service Manual only has basic info, remove plug, short it to ground, pull cord and check if with healthy spark. Connect red kill cord. One thing that find on 2 strokes 5 HP- OB's is that the black wire that connects to Ignition Coil terminal comes bit wider than it should and connector is not plugged firm to IC, with a plier close a bit connector to achieve a tight fitting on contact.
Happy Boating
pvanv
[h=5]SERVICE MANUAL : 1 & 2 CYLINDER 2-STROKES[/h]
Description Covers all 1 & 2 cylinder 2-stroke models.
Part #: 003-21035-1
List Price (MSRP): $50.00
