neil gleghorn
- Apr 1, 2013
- 1
Hi all
Hoping someone can shed light in my problem
Tohatsu 4hp 2 stroke model m4c 3f9 serial number 79130
Having removed the reed block/crankase cover while trying to resolve a non starting issue, to check the reed valves,
1. There are two reed valves , one is funtioning as it should, the other cannot open as the reed stop has it held in
the fully closed position, is this correct.
2. I have a spark but it is weak. The stator measures 53 ohms between the white and red/black wires.
3. The trigger measures 96 ohms between white/red wire and earth
4 The ignition coil measures 0.9 ohm between the spade terminal and earth
and , 58900 ohms between the spade terminal and earth.
Can anyone inform me if these radings are within tolerances.
Any help much appreciated.
Thanks Neil from the sunny Isle of Man
