Tohatsu 40hp not revving up
Mamiji
After changing the head gasket on my Tohatsu 40hp M40C, I am not getting the power which I was getting before and it sort of feels like it is back firing. Do I need to adjust the idling or have I missed or messed something :)
Would appreciate any help!
Mamiji
Paul, the timing seemed fine before until I changed the gasket and tried adjusting the Idling, whereby I might have messed the idling even more. Would that be the case or still do you think I need to verify the timing?
Thanks!
pvanv
Go through the carbs and check timing. something is amiss.
Sea Rider
Which was the torque force applied when changed head gasket, was it retorqued soon after ?
Happy Boating
Mamiji
Seems to be working fine now after re-torquing... may be that might have been the problem!
Thanks for all the help!
Sea Rider
Which was the re torque force applied in Newton Meters ? there's a bolt torquing sequence you must follow while torquing in torque steps...
Happy Boating
