julenisse11
- Aug 1, 2008
- 1
so my engine was under salt water a while ago, i got it into fresh water and serviced, they got the engine running again and all. and its been laying im my garage for a little while now.
i tried to start it up but its only makes a "click" when i turn the key.
i played abit the the gears on the starter and the bigger gear, turned the key and it poped up and worked. then i get my boat at sea, and it works for 4 seconds, and goes back to saying "click" when i turn the key.
i open the starter and grind over the copper stuff (brushes?) that spinns next to the magnets. and it worked for 3 more seconds before it went back to "click"
i tried to connect some jumper cabels from the battery and right onto the starter + - nodes.
i allso tried to take the cabels from my car and to the boat battery so the battery should be fine
so i really wonder if i should buy a new starter unit, or if the probleme can be elsewhere.
* Sorry for bad spelling, im from norway
