kevin_kill
- Jan 11, 2007
- 2
I have a 30hp motor on a 11ft Avon inflatable. I have had it for a little while. I ran it fine all day on a lake. I took it out to the ocean and I let it warm up and I thought I was off but as soon as I tried to push the throttle forward it started to sputter and had no power. I put it back at idel and it was fine. I tried it a few times and the same problem. I took it home changed the fuel filter and the fuel thinking that I may have mixed the gas wrong. I threw it in a barel and it ran great! Ran up and everything. I put it back in the water and the same problem came back. It seems like it will run fine in a barrel or with ears on it, but as soon as I put a load on it it doesn't want to get up and go. I can get a little bit of throttle out of it but as soon as I try to kick it up it sputters and wants to die. I am at my wits end with this one and I don't want to drive 4 hours to get some guy to look at it for 75 bucks and hour. If anyone can help me I would be in your debt!
Thank you for any help
Kevin
Kevin
