Tohatsu 30hp 2005 Idle Problem.
kole666
hi... i have a problem with idle on my tohatsu.. he not work on idle, It works for seconds and goes out.. I give him gas 20% and do normally. i dont know where is problem.. i change TPS and adjust air nozzle but not to her..
any 1 Similarly problem? tnx
raczekp1
clean thecarb. there are usaualy two circuits. 1 is slow spped circuit and high.
if it will not help check compresion readings.
when compression is low motor wil die on slow speed setings( idle)
kole666
I'll check it
but when I compiled it i check throttle body it looks pretty clean..
pvanv
Is your model MFS30B? If so, it is EFI, and there isn't any carb. If you get the diag software, you can connect a laptop, and check injectors, etc.
pvanv
No carb on an EFI motor.
pvanv
If you change the TPS, you must reset the TPS initial setting.
