I have an August 2003 Tohatsu 3.5 Engine which I run on my Avon Rover RIB.<br />I thought today that the outboard hadn't been run in over a month so took it outside and put it in the trough of water i usually use to clean it.<br />It started fine, I ran it on and off for about half an hour then tilted it up FORGETTING TO CLOSE THE FUEL AND AIR INLET ON THE FILLER CAP. I went inside to get a towel to dry it off and came back to see fuel leaking all out of the front by the controls and starter. I then got a little worried, put the engine back down and pulled the starter.<br /><br />It wouldnt go. After about 50-60 pulls it sparked, on about the third spark it began to turn over. The engine the started to run OK but there was a lot of smoke - but i'm pretty sure it usually smokes when it runs on high revs in the tank. I let it run and it seemed OK for about 5 mins then switched off and put it away.<br /><br />Was it my fault that this happened and fuel leaked out the engine or is there some problem???<br /><br />Please reply
