Tohatsu 3.3 leg probs...
Craig Killip
Hi all, please could someone mutter some wise words?<br /><br />I went to service my Tohatsu 3.3 lower leg. Took the oil drain plug out and nothing came out! Took the top plug out and found it blocked. <br />Realised I needed a strip down of the lower leg and gearbox. Turned out there was no oil in there!!!<br /><br />Cleaned all the parts with petrol (as everything was full of nasty dirty black gunk). Put it back together and it is making a horrible screeching noise. Any suggestions what is the likely cause? Bearings I think? Can I get these from any old bearing supplier or does it have to be Tohatsu? Is it worth doing? <br /><br />Many thanks.
manolis
Re: Tohatsu 3.3 leg probs...
If its the bearings its worth doing. They dont have to be tohatsu.
