phillnjack2
Ensign
- Apr 30, 2011
- 918
Ok this is a wierd one for me.
But im sure there is planty of good advice from those who know about these engines.
25HP tohatsu 2 stroke. from first starting it will idle ok in nuetral then put in gear,give it
wide open throttle and it takes off real good.
Infact power is instant.
It will run full throttle like a dream, then when you slow down it will run ok for about 2 mins then will start to realy bog down and vibrate bad.
If you dont give it a twist of the throttle to bring revs up high it will stop completely,
then have to start all over again.
If you leave the engine once stopped for 2 or three minutes it will be fine again, untill you slow down.
If we keep the throttle wide open it will stay running realy good and strong for ages.
The engine is on a 4 metre inflatable, with 1 person around 25mph, with 3 people 23mph ,so the full throttle is pretty good, and like i say will keep running no problem at WOT.
I have cleaned every single part of fuel system over and over again,checked for air leaks,changed fuel line etc.
The engine is an old 1980's M25-A2 model, 2 Cylinder 2 stroke ,short shaft,with electric start etc.
COULD THIS BE A COIL PROBLEM, its a double type coil ??????????
Any advice on this would be realy welcome.
phill
phill
