Esteban32696
- Jan 31, 2007
- 4
I have a 2004 Tohatsu 25hp, 4 stroke. It is very hard to start & will spin over forever. The only way I can get it to start is by opening throttle all the way,, try it , open throttle again, try it, etc,REPEATEDLY, while pumping the bulb. Bulb will lose some pressure while trying to start & after running.
After I finally get it started it will stall many times before running. ALSO, slow idle speed is rough , like a plug missing [ they are new], but once above mid- throttle, it runs very good & smooth. Top speed is fine. 23mph on a 16ft welded jonboat. Also, does just changing the carb-manifold gasket on this model, increase hp to 30 ?? PLEASE HELP !!
