Tohatsu 25C2 - Throttle Grip Tension?
kezguy
Is there a tensioner for the throttle grip?, It's a little loose and sloppy. Would like to tighten it up a bit. Thank you, Karl
phatmanmike
Re: Tohatsu 25C2 - Throttle Grip Tension?
keep it loose, nissans are famous for that, it falls back down to idle easier when yu let go, and safer, if you fall down, boat wont keep going full speed away from you
