Tohatsu 2 stroke 115A2 upgradable to 140HP? and proping issues NEARLY NEW BOAT!!!
Status
Not open for further replies.
Tohatsufan
Hi, new here, joined up specifically to gain some advice to help get a new boat I bought set up properly.
There was a previous thread on upgrading the 115hp tohatsu to a 140 in 2005 with the use of nothing other than a pair of pliers and a rule (ruler, depending on where you come from ;).
Is this still the case with the newer model tohatsu's (2012?)
The main reason i'm looking at this is because previously I had a 17 inch 3 blade prop and could only get 5000 rpm max at WOT (52-5700 specification range). Motor was really struggling.
I then went to a 15 inch 3 blade prop and lifted the motor an inch (highest setting) and can now hit 56-5700rpm WOT(cavitation plate was previously nearly 2 inches under water at 3/4 throttle with correct trim, hence lifting the motor)
Still very slack out of the hole, takes ages to get on the plane in good weather, so options are either look at buying a 4 blade SS prop or see if I can get some more HP out of the engine for free :) over here in Australia they want around $800 for a SS prop :(
Any help/feedback/suggestions would be greatly appreciated.
Kind Regards
Simon
pvanv
Re: Tohatsu 2 stroke 115A2 upgradable to 140HP? and proping issues NEARLY NEW BOAT!!!
Different carburetors, amongst other things.
TOHATSU GURU
Advanced the timing by two degrees and bend the throttle stop out of the way on the top carb. Poof! You have a 140.
Tohatsufan
Exactly what I was chasing, thanks elvin!! you rock ;)
pvanv
Yep.. effectively converting the top carb of the 115 into a top carb for a 140... :)
spacerust
Can the same be done to a 1988 Nissan 90HP NS90A? I'm looking to get more HP out of mine too. Are there any implications to doing this modification?
TOHATSU GURU
No and since it cannot be done there are no consequences
pvanv
Yep. Completely different blocks.
spacerust
i didn't mean from 90hp to 140hp. Is it possible to go from 90hp to 115hp? Or what can I do to get a little more power. I added a raised console and towers so I have added weight now. i have a 15 foot shalllowsport that is rated for max 115 but i can't afford to buy a new one and the compression all around is 132. I really need a better holeshot since i fish in less than a foot to a foot and a half most of the time. i have 17 pitch prop and usually have two to three at most on boat.
TOHATSU GURU
Nothing has changed.
Go to a four blade 17 pitch for better hole shot. You should only lose 2 mph at top end.
dbdanno
I have 1999 Tohatsu 115 HP and my question is can I bend the top carb throttle stop and not change the timing? I don't get wide open throttle now.
jbcurt00
10yrs later, better to start a topic about your Tohatsu & ask questions there
Closed
Status
