Hi All,
After going over a wave my tohatsu 18hp 2001 model outboard will only run with the choke 3/4 of the way on! Any ideas please fuel filter looks ok but is this the problem? Any ideas? tks
Go through that carb. Do a proper soaking, not just a spray. If filter is a year old, just change it. If you have E10 gas, run a water-separating filter. And make SURE you are running FRESH fuel.
Thanks Guys,
should I check the fuel pump diaphragm for damage and see if a check valve has come loose as doesn't look to complicated to do that. Or is it more likely that some foreign body has partially blocked a carby jet?
