Sea Rider
- Sep 20, 2008
- 12,345
A low hour 2 stroke 18 HP is misbehaving strangely. Idiotic boater smashed engine's back cowl onto something, broke the upper spark plug connector, sealed with epoxy cement. When at idle one of the cylinders misfires, something like brr, brr, brr, pum, pum, brr, brrr, pum, pum through prop exhaust. Seems to be a related electrical issue, probably a ignition coil near kaput and not a CD failure. Will wrap broken connector with several rounds of electrical tape and check if issue has gone.
All fuel related, tank to carb are immaculate clean including fresh fuel, new spak plugs. Before starting swap procedure, the fastes way to troubleshoot if counting with such parts. Has someone experimented same at some time ?
Happy Boating
Happy Boating
