New to the board...<br /><br />I have a 2000 15hp (15D2) Tohatsu motor that's given me problems since after the first year of use. The motor sputters, coughs, backfires for about 15 minutes then starts to runs ok. Lately it won't stay running at all even with various choke and throttle settings. It runs a few seconds with lots of smoke and backfiring. I've opened the carb and all seems ok with no obvious problems - very clean and float is ok. So now I'm looking at ignition issues. With a M530 peak voltage reading meter, I'm getting almost double the spec readings on the pulser and exciter coils but the CD unit outputs on the lower end of the specs. The exciter coil resistance is within specs. The ignition coil resistance reads ok on the primary but reads infinite on the secondary. I'm using Clymers manual which SUCKS for this diagnostic procedure.<br /><br />Any suggestions?
