tohatsu 15 hp, revs up and down
davidsg1a
Good evening folks I have bought a tohatsu 15 hp four stroke, it's only ran for 5 hours and hasn't been used for a year, took for a run and wen I put it in gear it revs up and down, I'm using clean fuel and oil level is fine, could anyone here help. David
Sea Rider
Welcome to Iboats,
How new/old is that engine ? When revving up/down does the speed increases/decreases accordingly ? Is carb, tank, fuel pump, fuel lines in immaculate clean state cond ?
Happy Boating
davidsg1a
The engine is 2012 and only had five hours run time, everything is in great condition, I'm very surprised I'm having a problem, the guy I bought it off took great care, when turn the revs up it goes for a few seconds then slows down then speeds up again.
davidsg1a
Sea Rider
Slows down, speeds up while maintaining a constat throttle setting ? Let's say 3/4 throttle...
Happy Boating
Sea Rider
Could be anything, inclined to a fuel related issue, probably a fuel restriction somewhere betweeen tank and carb, check ..
Happy Boating
HaMm3r
You are remembering to open the vent on your fuel tank (assuming it has one), right?
