I have a 15HP M15D2 2000 Tohatsu that I bought used, and it had been stored for a good while before I ever cranked it up.
Now that I have commissioned it, it runs fine, EXCEPT in the acceleration from idle to planing speed. Most of time, it is sluggish and pings during acceleration. Once it finally gets up on a plane it seems to run smoothly and at full RPM.
I have the factory service manual for an M15B2, but the Japanese/English translation is so poor that I'm having trouble understanding the timing section.
So far I have done the following:
- Changed to new spark plugs
- Dismantled and thoroughly cleaned the carbuerator and fuel pump
- Replaced the fuel pump diaphragms
- Changed to a new fuel tank with brand new high-test fuel with carefully measured TCW3 oil mixture
- Inspected all the hoses and wires and fittings on the motor
- Checked compression, and it is at 135 psi on each cylinder
- Verified there are no fuel line air leaks
- Made sure air vent on tank is open
- Checked and cleaned fuel filters
- Adjusted the pilot screw to 2 full turns out
- Verified that the cavitation plate is roughly even with the bottom of the hull
The motor is on a 10.5-foot Rigid Inflatable, and a previous 1984 Tohatsu 15 ran well on this same boat without the acceleration problem.
I am currently looking at whether the propeller is the right pitch (mine is model 8.5) and trying to determine what the timing arrangement should be.
Regarding the timing, it appears that the Top Dead Center (TDC) should be one long tic mark aft of the forward end of the Advancer Link Rod B (according to figure 10-11 in the service manual). My magneto coil plate, which has the timing marks, has a down arrow in place of one of the long marks, in the same location as shown in Fig 10-11, so I believe this to be indicating TDC on my engine.
But I can't tell what the timing setting should be for wide open throttle. Both the diagram (Fig 10-12) and the words are very confusing. There are no numbers and no TDC indication on Fig 10-12. It looks like the wide open throttle settings should be about 3 1/4 long tic marks BTDC. Anybody know if this is correct?
Anyone have any other ideas/suggestions/hints that might help me.
I am in Guatemala and don't have easy access to a service center.
