Tohatsu 15-2 Water leaking from cooling tube on the head
WaywardSun
HI.
I have a model ns15d2 which is no leaking water from the "base" of the cooling tube which runs along the top of the cylinder head. One end has the thermostat attached, the other is just above the cowling drain hole. I sucked some muck in with the water last week nothing was comming out pee hole. I took a strand of 12 g copper and stuck it into the pee hole. OK, so I stuck into every hole I could find on the back of the motor (brilliant). The pee hole has excellent flow, the water comming out of the base of the cooling tube is flowing nicely as well (which is my problem).
Do I have to replace the cylinder head or is there some mechanic "magic" that I can do to fix this problem?
Thanks in advance,
WaywardSun
pvanv
Re: Tohatsu 15-2 Water leaking from cooling tube on the head
Hard to say from your description, but your motor may have been heavily corroded. If so, and if your probing broke through the corrosion, you may need either a new head or a new block. If not, you probably just blew a head gasket.
