Ok, first I'll admit I'm an idiot and old enough to know better but I bought 2 used Seadoos (99 GSX Ltd and 01 GTX DI) and didn't get them checked out by a technician before buying. Both started out running just great. After a week or so the GSX starting taking on water when sitting still. We live on the lake so it sat for a couple days and I noticed it sitting very low in the back. Checked it out and it was full of water. After that it would not start due to water in the case. Pumped the water out and pulled it out of the water and to a Seadoo dealer. The service dept checked it out and cleaned/oiled the engine so that it ran. At that time they told me they couldn't find a leak but they'd gladly charge me more to take it on the water. I decided I'd take it back for now since we were going on vacation and make sure I ran it every day to keep the water from overtaking it. We went to Lake Cumberland, KY for a week and rode it several times a day with some water getting into the inside overnight. Each morning it cranked fine and bilged the water out. The last day I was running it and it just quit going about 40mph. I tried to restart it but just got a clicking noise, no cranking. When I got it home I had it on the trailer and put water into it and found that it was leaking around the intake grate. I took it back to the dealer and they confirmed that it was leaking from a crack near the grate. They stated that it looked as though it had been wrecked and the fiberglass repair was failing. They tried to get the engine fired up and were unable to do it and were even unable to turn the crank with a breaker bar. They were estimating over $5000 to fix it which is more than it's worth.
Couple questions: Should the shop have been able to prevent this major destruction of the engine? I know they should have been able to figure out where the leak was.
Second: I can likely do the fiberglass work and could rebuild or replace (with a rebuilt SBT engine) the engine. Is it worth it?
Thanks in advance for the help.
