Re: Toahatsu/Nissam 18 HP ID
9.9 comes factory restricted with different shape throttle cam mounted on magneto plate, if swapping complete 18 powerhead including carb to same base you could tell the visible difference. You could also have an updated 9.9 to 15 HP, or a complete powerhead 15 HP swap that will look same as an 18. The difference is internal 50 CC more. If you mount an 18 well tuned on a light sib/rib should give you minimum 20 knots at wot. Check with a GPS on a flat no wind track for at least 1/2 mile run.
Happy Boating
