Re: To build or not to build
CHARACTERISTICS <br />Length overall 20'-6" or 22'-4" <br />Beam 8'-3" <br />Hull depth 3'-8" <br />Hull weight (approx.): 1500 lbs. <br />Displacement @ 11" designed waterline 3100 lbs. <br />Cockpit Length, seat back to seat back: 13'-9"<br />Width, maximum: 7' <br />Passengers 8 <br />Hull Type: Vee bottom 15o hard chine hull developed for sheet plywood. <br />Power: Single or twin outboard motors; long or extra-long shaft for single, extra-long for twins. Optional power stern mounted inboard/outboard, v-drive or jet pump optional but not detailed. <br />Can the hull be extended or shortened? Not beyond the lengths listed. We do not recommend increasing the beam. <br />Trailer: For use with Glen-L Series 3800 trailer plans. <br /> <br /><br />PARTY BOAT, deck boat, fun boat, call it what you will. It's a spacious wide open cockpit sitting atop an efficient hull. Pack it with passengers and take off to a remote area for picnics. Tow water skiers? Right on, and there is plenty of room for kibitsing passengers. Fishing? Sure, add a trolling motor and equip the bow deck with a chair and you're set up for some wicked fly, bass or walleye chasing... and catching?<br /><br />I chose this one by Glen-l.
