Re: To anyone thats read my msds posts on fogging oil and seafoam !!
Thanks for the information and especially, thanks for taking the time to research and post your findings.
However, as a 23+ year Fire Service employee, please, please, please DO NOT create your own homw brew and attempt to fog the cylinders with flammable/volitale solution.
Although the ingredients and their (close to) percentages may be available, the items that you can purchase locally ARE NOT the same chemicals that the manufacturers use. They may have the same name, but the individual concentrations may be different. An example would be: Company 'X' uses 28% Napthalyne in it's mixture of fogging solution. However, that 28% Naptha might have 10 different chemicals in it at predetermined amounts than the Naptha you can get locally.
Another example is the posting I read about IPA. Some other posters mentioned that it must be Isoprophyl Alcohol. It would stand to reason...but what if it was something else?
Basically, what I'm saying is that the people that developed these solutions were schooled more than most of us, trained in the field of chemical analysis, has testing grounds available, and millions of dollars in backing for R&D.
I have seen many, many people injured or killed from doing things without the proper training or guidance. Why put yourself at risk to save $10-$15 dollars on fogging fluid once a year? Please think about it.
Thanks for reading.
