Benz Mondi
Thread starter- Joined
- Aug 30, 2010
- 125
Went to raise the my motor from an all the way down position. As normal I hit the up button at the switch I installed by the motor and only got a faint click. Hit the down button and it operated normally. Just in case, I went to the dash mounted switch got the same results. I tried to switch the relays but no change. Since I can't raise it manually with the TNT installed, I was stuck. What gives? Why only the click sound for up and normal sounding for down? What's the fix? Thanx.
